跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
No recognition by computer
I have three 7G ipod logic boards. None of them even beep when I plug them into the usb. (The usb does beep in the ports whenever I plug something else in.) Should a bare logic board make a sound when plugged in?
I did go all the way and assembled a complete unit, but I only get a white screen.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@rusty54 no the bare board will not be recognized. You will have to have something that at least resembles an iPod to get it recognized. You cannot test boards alone by plugging them into your computer. The white screen means that your backlight turns on. What else did you check?
这个答案有帮助吗?
得分 2
添加一条评论
Thank you for replying, oldturkey03. I have replaced the screen in my 1TB ipod which was working fine till the damaged the screen. Now the screen just displays white. Reset, disk mode or diagnostic are unuseable as the screen is all white. It will go through the motions of a reset, but the screen comes up white...no apple. Also, there is no longer a beep when I insert the usb cord. After 2 computers and three cords, I assume the problem is the ipod.
I have tried reseting the lcd many times, but it makes no difference, the screen is still all white.
这个答案有帮助吗?
得分 0
1条评论:
I have also disconnected the SDXC disk in hopes of a red X, but it made no difference. I also note that the screen is not as bright with the usb connected compared to just the battery. Lock switch works, but no audio. I have tried 2 LCDs, but no difference. (I have 2 more in transit from ifixit.
It worries me that there is no sound from the computer when I connect the usb...nothing happens. I thought that maybe Apples driver in the new version was at fault, so I installed a previous iTunes version. It did not help. None of my logic boards makes a sound as a standalone board or assembled unit. I have tried 3 usb cords without success. The ipod worked fine a month ago.
Is a lcd for a 6G compatible with the 7G logic board? I see that ifixit store makes no distinction.
完成的
添加一条评论
添加你的答案
mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 134
