Understanding the power to my door bell
Hi guys,
I would like to understand how my outside door bell light works.
Based on what I understand (the outside wire) it's one wire getting interrupted & when pressing the door bell it creates contact resulting in the inside door chime to move and make ding dung sound.
But how does the actual light outside on the bell light up since it's one wire (I.e. Positive wire)? As well as when I measure the voltage on the wire itself I'm getting 24V.
How is that possible I would like to understand that.
Same thing with my thermostat wire, when I measure the voltage I'm getting 24 volts but based on my understanding it's one wire making contact when requesting for heat. (It's heat only zone) so how come I'm getting 24 volts
12条评论
@abrahamyaris that should be an AC circuit so no positive wire. What voltage do you get when you measure AC? That is a really interesting question :-)
由 oldturkey03 完成的
I'm getting 24vac when I'm putting my multimeter on each of the door bell wires.
由 Abraham Yaris 完成的
I have 31 volts AC AT my doorbell button. Is this an anomaly??
由 Byron Highland 完成的
Frase the wire that it gets power from. You’ll find it connected to a 24v transformer being fed by 120v.
由 jw69922 完成的
Trace the wire, you can frase it too but I can’t help you there!
由 jw69922 完成的
显示更多的7条评论
