跳转到主内容
加入维修社区 - 创建账户
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
What year mac mini to purchase
What is the best year for a mac mini in terms of maintainability and upgradability?
I was about to purchase a brand new one from Apple but I discovered they were essentially sealed shut in terms of user upgrades and maintenance.
I'm thinking that the best thing to do would be to purchase as late a model as possible without getting one that cannot be easily upgraded. But, I don't know what year Apple began making units that were difficult, if not impossible, to upgrade.
I'm OK with anything but desoldering things off the motherboard. I want to get as fast a unit as possible so my plan was to purchase a low end unit, on eBay, and install a SSHD and RAM upgrade. I intend to use it primarily for running XCODE for development purposes.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Good Question!
完成的
I would recommend a dual drive setup SSD for the OS and swap/paging space and a standard HD for your files (not Fusion) or a dual SSD if you can swing it. As you are doing coding I would go with 16 GB of RAM.
完成的
添加一条评论
1个答案
已选择的解决方案
Over the years Apple has made the mini less upgradable. And I agree the current version of Mac Mini is very limited!
Here's the IFIXIT teardowns so you can follow along:
The 2014 model has soldered RAM you'll need to decide how much you'll need upfront as what you buy for the system will be what you'll be stuck with. It comes either with 8 GB or 16 GB of RAM.
The 2014 model also only offers a single SATA port {SATA III (6.0 Gb/s)} to support a standard 2'5" HD, SSHD or SSD drive. What would normally be the second drive bay is configured to support a custom Apple blade PCIe SSD drive. While the I/O of the custom Apple SSD is much faster than what the SATA port can offer you are limited to Apples SSD or one from OWC SSD options when its offered. The only rub here is you'll need to replace the Drive Tray to add in the Apple custom SSD if you don't buy a SSD configured system in addition to the SSD which is quite costly when bought as a spare. So I do recommend you think on what the largest SSD you'll want in this series and buy that model.
The 2012 & 2011 models offer two SATA bays. Which can support two or a combo of HD's, SSHD's or SSD's. Apple offered a Fusion Drive option in the 2012 model, one can create a Fusion Drive in the 2011 model as well. In either you must have a standard HD and a SSD drive, you can't use a SSHD or two SSD's. Here is the needed kit to add in the second drive: Mac Mini Dual Drive Kit and here is the IFIXIT guide to do it: Installing Mac Mini Mid 2011 Dual Hard Drive Kit or Installing Mac Mini Late 2012 Dual Hard Drive Kit
Both 2012 & 2011 offer support for two memory modules for a max of 16 GB of RAM.
So now you have the details on what is upgradable. Here's the specs for the different Mac Mini models to review: EveryMac - Mac Mini listing
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.图片
产品
Mac mini Dual Drive Kit
$29.99
Mac mini Mid 2011图片
指南
Mac mini 2011 年中版拆解
难度:
中等
15 - 30 minutes
Mac Mini Mid 2011 双硬盘组图片
指南
为 Mac Mini 中期 2011 安装双硬盘组
难度:
中等
2 - 4 hours
Mac mini Late 2012图片
指南
Mac mini Late 2012 Teardown
难度:
中等
Mac Mini Late 2012 双硬盘图片
指南
为您的 Mac Mini 2012 晚期款 安装双硬盘模组
难度:
中等
1 - 2 hours
Mac mini Late 2014图片
指南
Mac mini Late 2014 Teardown
难度:
中等
这个答案有帮助吗?
得分 8
4条评论:
Really excellent answer!
完成的
@mayer - Thanks!
完成的
Thanks for taking time to give me exactly the information I needed and explaining the trade offs so,well. I believe I will look for a 2011 or 2012 model with a SSHD and 16G if Imcan find a good one and plan on adding a second 1TB drive for auxiliary storage, Thanks again for the excellent response to my question. -- John B
完成的
@jobattle - If I've answered you question please take the time to score it (if you haven't) and mark your question as answered. Thanks!
完成的
添加一条评论
添加你的答案
John Battle 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 32
总计 8,752
