跳转到主内容
Long time of non use
I have a Pioneer PL-44F turntable that I haven't used for 20 years or more. It comes out of its base very slowly but sticks along the way. No other features or buttons seems to work. It seems that it the problem is not being used so perhaps moving them manually to loosen things up will do the trick? Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
arch if it moves out slow and sticky it is possible that the gear or the shaft are gummed up. Take a look at the image for the location of part 3 and part 6. See if you can clean those with some isopropyl alcohol and free them up.
这个答案有帮助吗?
得分 2
1条评论:
Old Turkey,
If I was to tear this unit down to that degree, I'd never be able to put it together again. It seems that the base is moving in & out easier, after manually helping it numerous times. However, the arm & platter do not move. Anything else you can suggest?
完成的
添加一条评论
添加你的答案
arch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 222
