跳转到主内容
加入维修社区 - 创建账户
Asus X200CA 笔记本电脑尺寸为 11.6 英寸,重 2.6 磅(约 1.18 kg)。它搭载 Intel® Core™ i3 3217U 处理器、Intel® ULV Pentium® 2117U 处理器或 Intel® Celeron® 1007U 处理器,配备 2 GB 或 4 GB 内存、320 GB 至 1 TB 存储空间、Windows 8 操作系统、高清摄像头,电池续航时间预计为 3 小时。
Why it wont charge
its not charging nor turning on why
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Did this happen out of no where? What is the history of the device? There isn't a whole lot of information to be able to provide an answer to your question.
由完成的 分享
添加一条评论
1个答案
Plug is Not Connected to Wall Outlet
Check to see if the charger is plugged into the computer and also an outlet. Try a different outlet to ensure that it is not a problem with the power of the first outlet.
Dead Battery
If your laptop will only function while being connected to an outlet, your battery may be faulty. To fix this, replace your battery.
Damaged Battery
If your laptop will not turn on, check your battery for any physical damage or water damage. If you find evidence of damage your battery will need to be replaced.
Issue with Charger
Check to see if the charger is one that is recommended to use by the manufacturer. If not, obtain a recommended charger. Check to see if your device will charge with a different charger. If this is the case you will need to replace the charger you have.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tinner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 29
总计 699
