跳转到主内容
加入维修社区 - 创建账户
这是一款配备 1.66GHz Intel Atom N455 处理器、10.1 英寸 LED 显示屏和 Intel Graphics Media Accelerator 3150 显卡的上网本。
How can I replace my hard drive?
How do I fix corrupt hard drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Make sure your laptop is completely turned off. Turn the laptop upside down, and located the sliding tabs on the battery. Slide the tabs into an inward position then take out the battery away from the laptop. Remove the bottom cover by pull the orange tab to the right until you heard a click sound. Gently disconnect the clips as you lift the bottom cover. Remove the four screws by using a Phillips PH1 screwdriver for the four black screws around the hard drive. Pull the hard drive towards the left using the orange tab until the hard drive is released from its receptacle. Replace your corrupt hard drive with a new hard drive for your laptop.
这个答案有帮助吗?
得分 1
添加一条评论
Nice instructions, I would go with an Ssd drive it will increase the speed a lot. Below are some different sizes and cost.
https://www.amazon.com/gp/product/B00OAJ...
https://www.amazon.com/gp/product/B01F9G...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Smitkumar Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 341
