跳转到主内容
Progress dial freezes when booting from any HD
Hello! I'm going through some aluminum PowerBooks, and I've found a couple that freeze on the Apple screen with the progress dial. Option mode and target mode work, and I was able to re-image the drive in Target mode from another machine, but when it tries to boot, it freezes again. It also freezes when I try to boot from an external hard drive connected to the machines via FireWire. I've swapped the internal drive with another drive that has Leopard on it, but that also freezes when it tries to boot. I've tried all the resets, memory, etc., to no avail. I'd say the logic boards are defective, except that the machines came to me with Tiger installed, and they booted up into the OS 100% when they had Tiger. I've tried putting Tiger back on in various ways, with no luck. But because I did witness them working with Tiger initially, I'm convinced it's not a hardware issue, but something I'm not doing right (or something I'm doing that they don't like, anyway). It almost makes me think they are in need of a firmware update in order to take Leopard, although I've never known an aluminum (or any Mac) to require that.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Don't you have any easy questions? +
完成的
What's a progress dial?
完成的
Nope, no easy questions, sorry. :-( The progress dial, the little spinning thing under the Apple symbol? Maybe there's a better name for it that I'm just not thinking of....
完成的
添加一条评论
1个答案
已选择的解决方案
I have
seen this with Intel Graphics drivers in extensions that are not needed.
I safe booted, and looked in Sys/Lib/Extensions and pulled all the video drivers that were non ppc and some ppc that were not germain to the AL G4 (know your VGC before attempting this) SO not to lose them I make an Extensions Disabled folder in Sys/Lib and moved them into there. Compare the Extensions from your "normal or install set" with the "safe set".
Your milage may vary.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
2条评论:
Thanks MacHead! Wow, that's something I would never have thought of. But would the fact that it does the same thing (progress dial freezes) when booting to an external hard drive containing the PPC version of Tiger not rule this out as the problem? Thanks again!
完成的
Not necessarily even the "PPC Version" includes intel drivers in extensions! Take a look.
完成的
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 966
