跳转到主内容
加入维修社区 - 创建账户
Nintendo 64 手柄(型号 NUS-005)的维修指南。该手柄于 1996 年发布,适用于 Nintendo 64 游戏主机。
Analog stick - Nintendo 64 Controller
Hi all,
My analog stick of mine controller is not working fine anymore. I found replacements on the internet. I found 2 different version.
I got version A in my controller. Can I solder version B in my controller?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
From a bit of quick research, it appears that it should work fine. Just make sure that your pin connectors line up. Beyond that, it looks like it'll be okay to swap them out.
Best practice would be to install the new thumbstick and before closing it up, test out the controller to ensure that the new thumbstick reacts properly to the game.
这个答案有帮助吗?
得分 0
添加一条评论
I'd say it's a bit risky to add one of those into your controller, because if you got a warranty for it (IF YOU ONLY GOT IT A SHORT WHILE AGO that is) you have to hack into your controller to install the analog stick, and opening it up usually voids the warranty. Also, I've heard that the replacement analog sticks aren't exactly the best. Look in the video below
https://www.youtube.com/watch?v=o3GYtAyR...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Uas 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 11
过去 30 天: 24
总计 1,163
