跳转到主内容
advertiser puts his spam in my calendar
This W W W . U G G T A . C О M managed to put their advertising in my calendar. My anti-virus Symantec Endpoint protection did not pick it up. Does anyone know how to get it out or where it is located or what I need to do to protect myself from this unwanted invasion?
I'm running Sierra
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
@mayer, no new suggestions for your problem, just trying to keep ? alive, hoping some one can help! Good luck.
完成的
I use the free MalwareByte Anti-Malware to remove adware from Macs, those that cause multiple tabs to open when you are trying to browse. Could it work for you too? I just had a customer mention he has this issue on his iPhone while while we were working on his computer, but we did not have time to work on it. He is dropping by soon.
完成的
@rany In general I try to stay away from free programs as most are viruses themselves. What was unusual on this one is that it placed it in my calendar.
完成的
The MalwareByte seems legit. From experience, it works well to remove adware and hasn't caused any issues that I am aware of.
完成的
添加一条评论
3个答案
已选择的解决方案
Hey @mayer, it looks like Apple has apologized for this issue and is actively working to fix it.
Here's a Gizmodo article on how to stop getting calendar notifications.
这个答案有帮助吗?
得分 3
1条评论:
Yes, that's the problem! Nice that Apple has apologized. It would be even nicer if they actually fixed it with a security update. Thanks for finding this ;-)
完成的
添加一条评论
@mayer , I could not find much info. on W W W . U G G T A . C О M, check this link to see if it is similar problem. Hope it helps.
https://www.reddit.com/r/apple/comments/...
这个答案有帮助吗?
得分 2
4条评论:
Well it's not an answer per se but looks like a lot of others are having the same issue. I subscribed to Reddit so maybe someone will find out.
完成的
@mayer ,Did a search, this may be what Gigabit878 mentioned. Mac computer Change advertising id in privacy
https://support.apple.com/en-ca/HT205223
完成的
@lpfaff1 That link is good but more for iOS. I did try going to System Preferences > Security & Privacy > Privacy > Calendars and saw no requests for access.
完成的
@mayer try looking in safari, maybe its under there.
完成的
添加一条评论
Change you advertising id, I forgot how to but it should be in privacy.
这个答案有帮助吗?
得分 1
1条评论:
This would be a great answer if you told me how to do it.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 161
