跳转到主内容
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
71 个问题 查看全部
Vertical color lines appear when turned on
Multi colored vertical lines appear when TV is turned on - they disappeared after a few minutes but now remain constant
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
I am having the same issue. And its getting worse. What can I do to fix this?
完成的
@starkwolf30 what have you checked? Same TV as the OP? did you check what was listed in my original answer?
完成的
I have the same problem.
完成的
it might be a bad T-Con board
完成的
添加一条评论
2个答案
已选择的解决方案
Gerald Herd could be caused by corroded or loose ribbon cables as well as loose TAB's. Of course it can also be the T-con board. Post some images of what your screen looks like with your question. For that use this guide. It will allow us to see what you see. Also, it helps if you can tell us what you have checked thus far.
这个答案有帮助吗?
得分 3
添加一条评论
Hi I have coloured lines centre of tv which are vertical
unplugged ribbon cables and put pressure on the cables going into screen
Lines are constant and go over picture on screen and menu bar
lines won’t change get smaller or disappear
many help would be much appreciated
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gerald Herd 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 3,330
