跳转到主内容
Down jackets wrap you in soft warmth, insulating your core from freezing temperatures and wind. They are highly compressible, extremely lightweight for their warmth, and ultra-comfortable for all day use.
40 个问题 查看全部
Zipper gets stuck all the time
Patagonia TorrentShell jacket
Zipper of my Patagonia TorrentShell gets stuck all the time. It stops in neck area when trying to get it closed. Fabric of inner stormflap gets stuck between zipper.
Has anyone tried to sew a some kind of reinforcement to stormflap? Maybe repair tape in flap will prevent it getting between zipper?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
villemitikka - I had this issue too and took my jacket to Patagonia - they ran 5 lines of stitching down the inside flap to stop it from snagging and it's worked perfectlyl. They have a free of charge repair or replace area in their stores.
Hope this helps!
完成的
John - Thanks for your answer. Sounds good and easy. Got to try stitching by myself.
完成的
添加一条评论
3个答案
已选择的解决方案
Here's the guide on zipper repair for the Patagonia:
Installing A Main Zipper In Your Patagonia Down Jacket
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
villemitikka , I do not own this type of jacket, on a jacket that I had, did have this problem, so what I did when zipping up I would use my index finger to keep (guide) inner flap material away in the collar/problem area while zipping up. Worked for me. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
try using a old candle and run it up and down the zipper a few time to both sides of the zipper it will make it slide with ease
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
villemitikka 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 6,167
