跳转到主内容
加入维修社区 - 创建账户
HTC 第三代智能手机,于 2015 年 3 月首次发布。相较于 M8 设计,其主要改进包括八核 Snapdragon 810 处理器和 2000 万像素后置摄像头。
HTC One M9 in weird boot loop
I have an HTC One M9 that is being super weird. Its stuck in what looks like fastboot mode and reboots every minute or so. OK..no big deal. It looks like someone tried flashing a custom recovery and failed. When I go to recovery mode or download mode, I get "failed to boot to X mode".
Figured ok, I'll check things out in ADB. ADB doesn't list it as being seen and I can't send any commands to it. I would write it off right there except that when I run a logcat and reboot the phone, ADB sees the phone disconnect. So the phone is communicating with ADB on some level, ADB just doesn't detect it.
I'm much more comfortable with Samsung boot issues. Anyone know anything about HTC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Rip HTC one m9
由完成的
Not rip quite yet. Firmware most likely needs reflashing because I unbricked an m9 before.
由完成的
How do I flash the thing?
由完成的
It's a bit complicated you need to use and to push the update file. When I get home I'll give you the steps. Its like copying an update.zip file to sd card. The problem is that the model number and other id needs to match.
由完成的
yea...tried adb push but adb doesn't see the phone
由完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Not to sure on flashing HTC like you I'm more familiar with Samsung . This may help though good luck
这个答案有帮助吗?
得分 4
添加一条评论
I just went through this with my M9 and it looks like the linked Youtube video is down. :/
[For this, I'm assuming the phone is S-On and the bootloader is locked. It also assumes that the eMMC chip hasn't hit it's End-of-Life and died]
The answer starts off with getting the right aosd.img for the phone. Then, with the phone in fastboot mode and connected to the PC:
Type "fastboot flash aosd aosd.img" and press Enter. This will give you back Download Mode. From there, the choices are:
If the bootloader is OK, you can boot the phone into Download Mode and try to re-flash the firmware using the official RUU .exe. [If the bootloader isn't OK, the phone may go into a reboot loop: To break the loop, hold the Power and Volume Up buttons]
If you are unsure of the bootloader, you can try reflashing the phone by putting the RUU .zip file onto a micro SD card and flashing from Download Mode.
The worst case scenarios I've seen so far are:
If the phone cannot be reloaded via the RUU and you're stuck S-On, you can use an XTC2Clip to go S-Off and reflash the firmware.
The eMMC has exceeded it's life cycle and gone completely corrupt and unrecoverable. At that point, the mainboard would need to be replaced or the original board would need to be reworked to put on a new eMMC chip (iirc, a new chip is ~$5. The main cost is having a reball setup and proper jig).
这个答案有帮助吗?
得分 1
1条评论:
Just switch off the location and the problem is solved
由完成的
添加一条评论
添加你的答案
Josh W 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 26
总计 5,437
