跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for electronic keyboards.
keys don't make sound Solved
I have a Yamaha PSR-210 electronic keyboard. The sound doesn't work. Is it worth repairing? I'm not sure how to trouble shoot to fix this? Does asking a question cost to get your answer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
i have a problem kind of similiar, except mine only has one key that doesnt work
完成的
cherylynn13 "Does asking a question cost to get your answer?" NOPE! all free help here. Welcome to ifixit :-)
完成的
添加一条评论
1个答案
最有帮助的答案
cherylynn13 first make sure that everything is hooked up correctly. Common mistake on this one seems to be that the sustain pedal gets plugged into the headphone jack, so check for that. If that is okay, you do want to use a pair of headphone and plug those in. If you get sound on those you may have issue with a bad headphone jack or the speakers. Let us know what you find. To do any further troubleshooting, you may have to take it apart and check a few things with a multimeter. Hope you are up for it....
I'd start by looking at the AM board
这个答案有帮助吗?
得分 3
1条评论:
After checking further, on your advice, a headphone jack adapter was found plugged in. I have never used headphones with it, so I wasn't looking for any such device. Problem solved!
完成的
添加一条评论
添加你的答案
cherylynn13 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 3,604
