跳转到主内容
加入维修社区 - 创建账户
第一代 Audi A4 于 1994 年 10 月首次亮相。1995-2001 年款的 A4 车型基于大众 B5 平台打造。
dashbord is not working
hi
i have an audi A4 1996 , suddenly the rpm , speedometer , temperature , gaz level and all other indicator was disappear , but the car steel running ,
any idea why this is happen ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Have you checked in the fuse panel, that the fuse for the instrument cluster is OK?
Here is a link which shows the fuse box location and the allocation of the fuses. The fuse marked as Fuse #5 "Control unit for Instrument Cluster is the one you have to locate.
If you replace the fuse and it 'blows' immediately or shortly after, there is a problem and it should be checked out by either an auto electrician or an Audi dealer to find the cause..
It may be also have been simply that the fuse has simply failed. There are a few causes: fatigue due to age,mechanical failure of the fuse due to vibration etc.
https://www.manualslib.com/manual/396576...
这个答案有帮助吗?
得分 1
添加一条评论
Audi Dashboard Warning Lights: Their Significance and How to Respond
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
elie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 50
总计 9,033
