跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 531s 台式电脑。
Computer won't power on
Computer won't turn on seems to have no power
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@wrc1970 what have you checked? Power to the outlet? Checked your power supply? You have a multimeter? The more information you can give us, the greater the chance of getting valid answers.
由完成的 分享
添加一条评论
2个答案
> If your computer is not opening so firstly you need to check your switch is on or not on maybe your didn't on your power switch.
> You can check your power cable also. You can take out this power cable and put in another computer so like this you can check your computer power cable.
> Maybe your power cable port is not working.
> You can check your RAM also because some time because of dust RAM doesn't work . So you can remove your RAM and clean to pins of RAM .
这个答案有帮助吗?
得分 0
添加一条评论
First check your power switch from the wall if its working fine the check your power cable which is connecting with your computer then or may be check your power cable port is not working or check your motherboard because some time its happen that your motherboard is not pass through the power to the circuit and remove the RAM from your computer and put it back it'll gonna help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wayne Collins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,043
