跳转到主内容
加入维修社区 - 创建账户
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
No engine light on dash
having problem engine light will not turn on with key on have two of the same trucks one does the other does not and i cant read the codes
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
miz4getful, See Brandon B. and oldturkeys answers above or Re POST year, make, model,engine, transmission and complete question so we, here at ifixit can answer your question effectively.
完成的
@lpfaff1 really? Another Canuck! Well, greetings from an expat.
完成的
Thanks for the greeting oldturkey03, all the leaves are down, you know what comes next, have a great day.
完成的
添加一条评论
1个答案
已选择的解决方案
miz4getful, check the bulb for missing/loose/burnt out(exchange it for a known good working one and check the instrument cluster back side for damage, burn mark,corrosion, solder joint break, etc. and if OB2 port is not working check your cigarette lighter fuse for being blown. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
miz4getful 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 117
