Hi,
Try contacting the Samsung technical service section in your location (country even) and asking, as there is none available online, whether they have the firmware for your particular model available and could you either purchase it or get it somehow, so that you can re-install the firmware using a USB flash drive. (This approach worked for me with my TEAC TV which had the problem of powering on with no picture or sound problem. There was no firmware available online but tech support emailed it to me.
It never hurts to ask, the worst that they can say is no.
I found this while reading the guide for your TV and while it will probably do nothing it never hurts to try.
''Problem : The ‘Resets all settings to the default values.’ message appears.
Solution : This appears when you press and hold the EXIT button for a while. The product settings are reset to the factory defaults.''
So I was thinking that perhaps you could try holding the exit button on the remote for a while, 30 seconds say and see if anything happens. Worst case is that you have just wasted 30 seconds of time.
8条评论
MaE sTrO are you referring to physically identifying the EEPROM?
由 oldturkey03 完成的
Yes actually, i found several posts about unBricking /resetting the EEPROM would fix this, there is no harm in trying but just like you said i can't physically identify which 8 pin chip is the EEPROM on the board.
由 MaE sTrO 完成的
by the way here are some of the links that i'm trying to follow :
https://wiki.samygo.tv/index.php5/UnBric...
https://www.youtube.com/watch?v=DZnlD24f...
由 MaE sTrO 完成的
MaE sTrO post some high res images of your boards with your question. That will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that
由 oldturkey03 完成的
I've checked on the schematic and it looks like you are looking for IC5004 (Atmel 24C256). sorry I do not have the board layout
由 oldturkey03 完成的
显示更多的3条评论
