跳转到主内容
Help with finding EEPROM
Hi,
I have a 32" samsung le32a456c2d , after entering service manual and changing some options, all what i have now is a black screen, i tried everything nothing works until i found that unbricking my EEPROM ( RESET) may do the job and my TV could work again, the problem is that i searched everywhere on the web and checked the MB multiple times i can't identify the EEPROM i can provide pictures if needed .
Any help is really appreciated,
Thanks in advance.
Just added some iamges :
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
8条评论
MaE sTrO are you referring to physically identifying the EEPROM?
完成的
Yes actually, i found several posts about unBricking /resetting the EEPROM would fix this, there is no harm in trying but just like you said i can't physically identify which 8 pin chip is the EEPROM on the board.
完成的
by the way here are some of the links that i'm trying to follow :
https://wiki.samygo.tv/index.php5/UnBric...
https://www.youtube.com/watch?v=DZnlD24f...
完成的
MaE sTrO post some high res images of your boards with your question. That will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that
完成的
I've checked on the schematic and it looks like you are looking for IC5004 (Atmel 24C256). sorry I do not have the board layout
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
Hi,
Try contacting the Samsung technical service section in your location (country even) and asking, as there is none available online, whether they have the firmware for your particular model available and could you either purchase it or get it somehow, so that you can re-install the firmware using a USB flash drive. (This approach worked for me with my TEAC TV which had the problem of powering on with no picture or sound problem. There was no firmware available online but tech support emailed it to me.
It never hurts to ask, the worst that they can say is no.
I found this while reading the guide for your TV and while it will probably do nothing it never hurts to try.
''Problem : The ‘Resets all settings to the default values.’ message appears.
Solution : This appears when you press and hold the EXIT button for a while. The product settings are reset to the factory defaults.''
So I was thinking that perhaps you could try holding the exit button on the remote for a while, 30 seconds say and see if anything happens. Worst case is that you have just wasted 30 seconds of time.
这个答案有帮助吗?
得分 3
4条评论:
Thanks Jayeff for the reply, i already tried contacting Technical Service, had no luck with that, I also tried resetting with exit button and resetting through service menu ( blindly) since i have no image at all, nothing works till now that's why i think the EEPROM is my last option.
完成的
Hi,
There is always this option as long as the board is the correct one!
http://picclick.co.uk/Main-board-for-LCD...
完成的
That would definitely be my last option buying a new board, Thanks.
完成的
Hi, Just saw you comment re the links. Don't suppose your mainboard was as friendly as the one in the video where it actually said eeprom on the board? Maybe Googling the package number on the likely looking ICs will help to identify their purpose.
完成的
添加一条评论
添加你的答案
MaE sTrO 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 6,333
