跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Adhesive Strips Replacement - Removing old adhesive issue
I installed an SSD on this model about a month ago. The top right corner of the screen started to pull away from the adhesive for some reason so I am redoing the adhesive strips but I'm having a hard time getting all of the adhesive residue off this time. Do the strips 'need' to be put on completely clean plastic/glass to work effectively or is it ok if some glue residue is left on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I like to completely clean them with no reside. Use some Goo-Gone on a paper towel to get the tough stuff off.
Goo Gone Pro-Power Goo & Adhesive Remover, 8 oz
这个答案有帮助吗?
得分 3
1条评论:
I usually use goo gone for sticky stuff, but wasn't sure if that would be ok on a computer. Thanks!
完成的
添加一条评论
添加你的答案
scentaur 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 331
