跳转到主内容
Waterproof digital camera released in 2014. The Olympus Tough TG-3 is a Wi-Fi capable, compact camera.
8 个问题 查看全部
How do I power on my Olympus Tough TG-3 Digital Camera?
The camera will not power on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Open the battery/card compartment and check to make sure a battery is installed. If you do not have a battery installed insert one and check to see if the camera will power on. If it still will not check battery to make sure it is fully charged. After checking if is fully charged and reinserting battery, try powering on the camera again. If the camera still does not turn on you may have a faulty battery. You may need to purchase a new battery.
这个答案有帮助吗?
得分 0
4条评论:
What if the battery is proven to be good?
完成的
What if the problem happens with multiple batteries?
完成的
@bobbytra your camera not turning on even with new batteries? What have you checked? Your camera is a Olympus Tough TG-3?
完成的
It is. I "recharged" the batteries and put them in again. No use. What else can I check?
完成的
添加一条评论
添加你的答案
Natalia Morales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 233
