How do I power on my Olympus Tough TG-3 Digital Camera?
The camera will not power on.
Open the battery/card compartment and check to make sure a battery is installed. If you do not have a battery installed insert one and check to see if the camera will power on. If it still will not check battery to make sure it is fully charged. After checking if is fully charged and reinserting battery, try powering on the camera again. If the camera still does not turn on you may have a faulty battery. You may need to purchase a new battery.
这个答案有帮助吗?
What if the battery is proven to be good?
What if the problem happens with multiple batteries?
@bobbytra your camera not turning on even with new batteries? What have you checked? Your camera is a Olympus Tough TG-3?
It is. I "recharged" the batteries and put them in again. No use. What else can I check?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 259
