跳转到主内容
The C700 is a budget PC notebook released in 2008 by the Hewlett-Packard Company, or HP, through its Compaq subsidiary.
6 个问题 查看全部
Question 1:  Why does my laptop keep shutting down?
While using my laptop it continues to shut down mid use. Why is this happening?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Student Question
完成的
添加一条评论
1个答案
最有帮助的答案
The most likely reason for your laptop to shut down mid-use is that the cooling fan has built up debris in it, causing it to be unable to cool the device. This makes your laptop overheat and turn off. I would recommend using canned air to blow out the vents leading to the fan. These are located on the side and bottom of the laptop. If the issues persists, you can open the device up and check to see if there is debris build up in the fan or if it requires replacement. To get to the fan to clean or replace it, follow the instructions in this guide.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rob Yule 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 154
