跳转到主内容
加入维修社区 - 创建账户
Google 推出的第五款 Nexus 手机。该机于 2013 年 10 月 31 日正式发布,配备 4.95 英寸 1080p 显示屏、2.26 GHz Snapdragon 处理器并支持 LTE。搭载 Android 4.4.2 (KitKat) 系统。由 LG 制造。
Nexus 5 rebooting randomly
My Nexus 5 is restarting on its own. Not bootlooping - it is often able to complete the booting process and be usable for a few minutes before restarting again. This happens regardless of whether the phone uses battery power or is plugged in. Tried flashing it back to stock (factory images: KitKat, Lollipop, Marshmallow) - it didn't help, so it looks like a hardware issue. When first turned on after being idle for an extended period it usually works longer before rebooting, then reboots become more frequent.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Incidentally, the random restarts don't happen in flashboot or recovery modes.
由完成的
HI! I have a completely similar problem with my nexus. This does not seem like a problem with the power button, since the nexus does not show the android power menu before rebooting or shutting down. Did you find a way how to fix this? Thanks in advance.
由完成的
添加一条评论
3个答案
Very common power button problem. Simple replacement would fix this problem!
这个答案有帮助吗?
得分 0
2条评论:
no its a motheboard problem
由完成的
@zengr Why do you think so?
由完成的
添加一条评论
Yep it's very likely a faulty (shorted) power button. Don't let this go on for too long as constant reboots can and will damage the storage portion of your phone. If it goes on for too long the software will corrupt and the storage won't mount and you'll have a bricked phone.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for your answers. I am just curious though: if the power button is the culprit, why would the reboots become more frequent the longer the phone is kept on? When I first turn it on after it's been off for a long time, it will work for about 10 minutes, then reboot itself, then work for for another 5 minutes, reboot, work for 2 minutes, and then start rebooting constantly. This pattern occurs every time it's turned on from "cold" state. To me this sounds like an overheating issue somewhere, but the phone does not actually overheat. I even tried replacing the battery, as I had a similar problem with another phone which I was able to trace to a bad battery. But here the battery was not the issue. So why would a shorted power button cause a pattern like that?
P.S. I am not particularly handy with a soldering iron, so I am trying to exhaust my other options before replacing the power button. And also - to use the opportunity to improve my understanding of how phone components actually work.
这个答案有帮助吗?
得分 0
1条评论:
I'm guessing it has something to do with temperature or perhaps it's the spring inside the button itself that fails. You can always try to take out the board and give it a good scrub with alcohol and see if it helps. It should but problem will reoccur again eventually
由完成的
添加一条评论
添加你的答案
Gene 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 2,035
