跳转到主内容
The Canon ELPH Z3 model camera was released in the United States in March 2012.
3 个问题 查看全部
Why doesn't my camera's charge last long?
I turn on my camera and take pictures for a little over an hour and the camera keeps dying. I charge it for the required amount of time for a full charge and still get the same results. Is there any issue with the camera itself or is it a battery issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The reason for this issue appears to be a battery issue. If you have had your device for a while, it may be time to replace the battery. Batteries indeed have a lifespan and the longer that they are in use the less efficient that they can be. Your camera's battery seems to have seen better days. Before replacing the whole battery, make sure all connections are correct and strong. If your issue repeats, it is time to replace your camera's battery which can be done so by following the guide for battery replacement that we have provided. Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Barros 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 107
