跳转到主内容
加入维修社区 - 创建账户
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Mac won't turn on after power surge
We heard a pop and started to smell smoke, and realized it was from the outlet we had my mom's Mac plugged into after she tried to start her it, and nothing happened at all. I believe that the surge fried the psu because there was smoke residue on the inside of the display, and 0/4 of the indicator LEDs are lighting up when I took it apart. I'm wondering if that's a correct assumption, and if there is a guide to replacing it if the psu is the issue or whatever else might be the problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Issac, if you open it up and can take close pictures of any damage you see and add them to your question(link below will show how to add image), I am sure this will give the ifixit volunteers a better idea of what will be required in the repair.
在已经存在的问题里加入图片
完成的
UPDATE: After opening it up, there doesn't appear to be any damage to the power supply itself. Is there any where I can find a pinout for it to check the voltage levels?
完成的
添加一条评论
3个答案
已选择的解决方案
You are correct, at the minimum the power supply is fried. Here's what the diagnostic lights indicate:
iMac Intel 24" EMC 2134 and 2211 Diagnostic LED's
According to your exact model the power supplies are:
661-4478 250 watt or
661-4422 240 watt
This summer I found a suppler out of China on eBay selling them brand new for around $27.
Probably old new stock that they are just trying to move.
I would wait the extra time rather than putting in a used part.
There does not appear to be a guide for the 24", but the installation for the 20" should be almost identical.
iMac Intel 20" EMC 2133 and 2210 Power Supply Replacement
If you can't find the part at a decent price, i.e., under $50 I would be reticent to spend a lot of money on a 9 year old machine. Your hard drive data is most likely recoverable using an adapter or a 3.5" external enclosure.
A working unit can be had on eBay for $200, so keep in mind what your machine is worth. http://www.ebay.com/itm/Apple-iMac-A1225...
iMac Intel 20" EMC 2133 and 2210 Power Supply图片
指南
难度:
中等
30 minutes - 1 hour
iMac Intel 24" EMC 2134 and 2211图片
指南
难度:
中等
15 minutes
这个答案有帮助吗?
得分 2
添加一条评论
Isaac, Electronics are often covered by home owners insurance for this, you may want to check and see if the computer is covered under your mothers insurance policy and make a claim, repair/replacement if deductible is not too much. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
My Imac hasn't been turning on after a power surge from a blow-dryer. However the imac was plugged into a surge bar. I have read numerous reviews of this happening to people and someone said they talked to a worker at an apple store and he said that your computer goes into a locked state anywhere from 24-72 hours after. I just want to know if I should leave my computer unplugged or plugged in while I wait for it to decide when it wants to turn itself back on? Does this matter?! Any help would be appreciated :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isaac Graham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 4,957
