跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv4000 笔记本电脑(型号:EC681AV)于 2005 年 3 月发布。它运行 Windows XP 操作系统。
Why is my computer overheating?
My computer is overheating when I use it for a long period of time. The fan is also making a whining sound when it is on. How can I fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I would also try checking out the fan. Using a can of compressed air to clean out any dust or dirt can help significantly if you have never done it before (maybe even up to 10 degrees Celsius). Just as good practice, I would give it a quick blast of air every few weeks, maybe once a month... it couldn't hurt! This also applies to desktop computers.
If you computer is still overheating, you may want to check out a guide for reapplying thermal paste to the CPU of your computer. If thermal paste is old and hardened, it won't draw away heat like it should and this heat could damage your computer and make it feel very hot.
'Also, using a computer for a long period of time may just make it hot, even if everything is working fine. Taking a break every few hours and allowing it to cool down should help the longevity of the computer. Alternatively purchasing a cooling pad for your laptop could allow you to comfortably work for longer.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
chances are it could be the fan inside your computer. I would go ahead and try that
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nick LaMarche 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 26
总计 481
