跳转到主内容
加入维修社区 - 创建账户
Nikon D80 是一款 1020 万像素的数码单镜头相机,于 2005 年公开发布。它主要用于数码照片拍摄和摄像。
SD card slot problem
SD Card will not click into position, it bounces back out, I can shut the door and make it go in, then the review gives me the message there is no card.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi, Have you tried a different SD card to see whether the problem is with the card or the camera?
由完成的
添加一条评论
3个答案
最有帮助的答案
I had this issue, did some research and found out that a tiny sliver of one of my SD cards could have broken off into the chamber. I got a flashlight and WA LA.... yes, that is what happened. I watched a video of a guy who dug his out himself. I did not have such luck, and am taking my camera into a professional who will charge me 30 bucks to get it out. So, get a light and look!
这个答案有帮助吗?
得分 2
添加一条评论
You know the card has to be pushed against the spring until it "clicks"?
Might be that the mechanism which holds the card in is broken and hence the card bounces out.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem with my D80. I sprayed some compressed air into my SD card slot and it started holding on to the card again. Got lucky. My guess is there was some debris present that prevented the SD card retention mechanism from engaging.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
photokellytaylor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 1,440
