跳转到主内容
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
51 个问题 查看全部
Why is my timing chain loose?
I got valve cover off passenger side head and was checking out the timing chain and it was tight. Then turned crank to where timing chain moved about 2" and checked it again. It was loose. Is this normal or do I need to fix something?
2000 expedition 5.4l
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@weelee why did you check the timing chain? What are the issues with your Ford? Anything related to the timing going on? How many miles are on your engine?
完成的
添加一条评论
1个答案
已选择的解决方案
@weelee , Lee, sounds like you have an issue, could be stretched chain, worn/broken guides, worn timing gears but the biggest issue here is probably a faulty timing chain tensioner, could be a combination of wear on all timing chain components.
Since this is what is known as a interference fit engine, it is best to change all the components and the timing chain and be sure to use the Ford recommended oil in your 5.4L. Check the attached video links, showing tear down, timing component wear and failure. Good luck.
https://www.youtube.com/watch?v=zkzsnie4...
https://www.youtube.com/watch?v=aUBx0RXj...
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
lee fletcher 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 14
总计 2,563
