跳转到主内容
Sony Xperia Z3 Compact released in Sep. 2014.
Bottom half of screen unresponsive to touch
After a small fall from a counter top, the bottom half of my phone screen has become unresponsive to touch. This means I can not access my phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi, Until you get it fixed, can you use the phone in 'landscape' mode, i.e. turn it 90 degrees to the right?
完成的
Hello, unfortunately the lock screen does not seem to rotate so this has been unsuccessful. Thanks for the suggestion.
完成的
添加一条评论
3个答案
已选择的解决方案
Here’s how to replace the digitizer:
索尼Xperia Z3 Compact LCD屏幕更换
Here’s the part: Sony Xperia Z3 Compact Screen
and the adhesive strips you will need:
Sony Xperia Z3 Compact Back Cover Adhesive Strips
This custom cut adhesive film secures the rear cover panel of your Sony Xperia Z3 Compact smartphone.图片
产品
$2.99
Replace a front glass LCD digitizer screen compatible with the Sony Xperia Z3 Compact model smartphone.图片
产品
$49.99
这个答案有帮助吗?
得分 3
添加一条评论
Lucy,
Sounds like the digitizer was damaged during the fall (or sudden stop at the end). The phone could need a new digitizer, or the plug could have just become partially disconnected.
这个答案有帮助吗?
得分 1
3条评论:
Thanks for your suggestion! Where is said 'plug'? Do you think this is something I can access or is it likely the phone will need to be sent back to Sony for repair?
完成的
You would need to open the phone to get to this plug. If you have never opened a phone before then I would recommend having a professional do it. Just about any repair shop should be able to do it.
完成的
shelton is definitely right, it is the problem with digitizer. you can replace the digitizer only but the problem is lcd screen was glued to digitizer glass much like iphone screen, it is a hassle to remove the glue and requires technique so it is better to replace lcd fullset. if you wish to know how to open the phone try watching tutorial on youtube.
完成的
添加一条评论
Your z3 compact screen maybe damaged by dropped, i suggest you try to disassemble your z3 compact then reconnect the screen flex cable. see if the screen problem is cause by the screen flex cable loosen.
If flex cable reconnection can not fix the screen problem, then you should turn to the hardware solution: change a new screen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lucy Adkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 11,715
