跳转到主内容
加入维修社区 - 创建账户
这是一系列帮助修理洗衣机的指南和支持。
LG WASHER Direct Drive won't spin
The drums turns in normal wash mode but as soon as the indicator light blinks between wash and spin the drum stops spinning and a strange rumbling noise is heard. We did do the pull plug out for 1 minute/open door 6 times in less than 12 seconds thing. WE have an LG Direct Drive front load washer. Do you know what it might be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Sandra Roberts what model is your LG washer?
完成的
Direct drive no belts or coupling plastic spline is ok
完成的
添加一条评论
1个答案
已选择的解决方案
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
这个答案有帮助吗?
得分 4
6条评论:
It’s a direct drive so no transmission. The motor is directly connected to the drum
完成的
direct drive it has no belt or transmission
完成的
hahahah they did not help at all. I had the same problem. It will not spin and I have no transmission and no belt because it is direct drive.
完成的
@shane35741
What is the model number of the washer?
完成的
Upside down f and then a e I have a direct drive lg
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Sandra Roberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 35,678
