跳转到主内容
An Amazon tablet released in 2014 featuring a 7 inch HD color touchscreen display.
Why can't I connect my device to the internet?
My device can't access the Kindle Store.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Student question
完成的
添加一条评论
1个答案
已选择的解决方案
  • Try to restart the device by holding down the power button for 40 seconds until the device turns off, then turn it back on. Also make sure Wireless Connectivity is turned on in Settings.
  • If this doesn't work your tablet may be running outdated system software. Instructions on how to update the Fire HD 7 (4th Generation) can be found here.
  • If you are still having issues the problem may be with your actual WiFi. In this case check the internet connection of another device, if that device can't connect either try turning your router off and back on again.
  • Additional help on this issue can be found here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Mellinger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 223
