跳转到主内容
加入维修社区 - 创建账户
Asus ZenPad S8 是 Asus 推出的一款 8 英寸 Android 平板电脑。于 2015 年 6 月发布。型号:Z580CA。
black screen death frozen
my zenpad froze when i was playing a game , them the screen when black i can see it the back light but still black. i need to know if there is any way to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
[Future reference]
I had the same issue. The Zenpads don't use the standard power+vol. up reboot method, but if you hold power + vol. down, it should put you into a reboot screen after a short bit. Just select "Continue Power On" from there and it should work.
这个答案有帮助吗?
得分 4
5条评论:
I've had the same issue, and tried that. It made the backlight turn on and off, but did nothing to actually fix the problem. Am I doing something wrong? Do I just need to wait a little while after? What's going on?
完成的
THANK YOU SOOOOOO MUCH!!! I did exactly as you said and BOOM....reboot screen popped up and life is good again
完成的
Thank you very much! Just had the same problem and found your answer!
完成的
omg thank you soooo much this tablet was my only method of communication and now it works thank you fellow gamer
完成的
It did not work for me. The screen is having a blue line straight down on a black screen
完成的
添加一条评论
David, my Zenpad S 8 showed weird rainbow colors & was unresponsive to touch before it went black. Upon rebooting, like you said, I could tell (especially in a darker room) via the backlight that it was on, and using the volume keys the speakers responded also indicating it was on. I will need to contact Asus & send them a video of what's happening, but for now I have discovered a temporary solution. Believe it or not, giving a hard rap with a knuckle or two in the center of the back of the tablet springs the display back to life. I'm guessing something must be connected poorly in the inside. Give it a try.
这个答案有帮助吗?
得分 3
4条评论:
In my case, the tablet was still under warranty, so Asus fixed it, although they didn't make clear what they did. If the tablet's not under warranty, from video's like this one https://www.youtube.com/watch?v=JpJs_OI8... the problem is probably that the connector from a ribbon cable or two has gotten loose. Look at Amazon, Ebay, Alibaba, etc. for a kit to open most phones & tablets. The cost should be less than US$10. The fellow in the video uses a credit card! Anyway, the idea is to open the device and re-seat the ribbon cable(s).
完成的
almost buying a new one, this is working for me, thank's a lot.
完成的
I had the same issue, sent it back to Asus and they returned it "fixed" without saying what they did. A few months later, same thing. Same process. The now twice "fixed" tablet lasted a few months, then reverted to the same issue again. Would I buy another Asus? Am I impressed with their tech service?
完成的
I used the "hard rap" trick and it worked for a 10 years old asus tablet...
完成的
添加一条评论
an Tablet LCD was Crushed by the Foot of My Sister
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Guilherme 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 14,976
