跳转到主内容
The iRobot Roomba 770 is a cordless, autonomous vacuum that will clean your floor without supervision.
23 个问题 查看全部
The side wheel is spinning backwards, how do I correct this?
The side wheel on my Roomba is spinning backwards, how do I make it return to its correct orientation?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Student question
完成的
添加一条评论
2个答案
已选择的解决方案
The most common problem is an obstruction preventing the wheel from turning the correct way. The obstruction will need to be removed. The faceplate will need to be removed to fully access the wheel. Once the obstruction is cleared, the wheel should return to spinning the correct way. More details may be found here
这个答案有帮助吗?
得分 2
添加一条评论
The most common problem is an obstruction preventing the wheel from turning the correct way. The obstruction will need to be removed. The faceplate will need to be removed to fully access the wheel. Once the obstruction is cleared, the wheel should return to spinning the correct way. Additional information can be found on the troubleshooting page.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Horvath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 64
