跳转到主内容
加入维修社区 - 创建账户
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
iMac won't power on. How do I check this model's power supply?
My iMac won't power on at all and I suspect the power supply is the issue. I've searched everywhere I can think of, but no one has a tutorial on how to check it on this particular model. I was able to disassemble it without any trouble and I removed and inspected the power supply visually, but I'm hoping someone has advice on how to test it with a multimeter. I haven't been able to find any pinout or voltage information for it. Maybe the same unit is used in other models? Any help would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I also was wondering if i measure the veiwable area of the screen it's 21" the entire face is 24" so is this a 21" or a 24" Imac?
完成的
添加一条评论
3个答案
已选择的解决方案
Just to the right of the RAM slots you will see the diagnostic LEDs. Tell us which ones are one. If just the first then you need to replace the power supply.
Here's the power supply: [关联产品丢失或禁用: IF169-000]
There's no teardown for this model yet but this guide should get you there: iMac Intel 17" Power Supply Replacement
这个答案有帮助吗?
得分 6
5条评论:
good answer +
完成的
I'm guessing if no LEDs are on, as is the case with mine, then it's *definitely* the power supply?
完成的
------------ Yes.
完成的
If you are replacing your power supply and don't already have a set of small torx drivers the http://www.ifixit.com/Tools/54-Piece-Bit... and http://www.ifixit.com/Tools/26-Piece-Bit... have the required torx bits, plus lots of other handy bits, and are a great deal compared to purchasing the individual drivers.
完成的
It was, in fact, the power supply. I followed a tutorial on this site to get the case opened and replace it. This is the correct power supply: http://www.ifixit.com/Apple-Parts/iMac-I...
完成的
添加一条评论
If no lights are on can you say its the power supply or can you say its the power supply and/or the logic board? One would think testing the PS would be in good order before assuming its bad.
这个答案有帮助吗?
得分 1
添加一条评论
Not for nothing, but my 24-inch mid 2007 iMac also went completely defunct in one power cycle. I actually brought it to an Apple Store where they replaced (according to the paperwork) power supply x2, backplane, and main logic board. They ended up returning it to me "no charge" and pulled the hard drive at my request.
I'm following up to ask you if you have had success with your repair. I'm leaning toward replacement but if this problem turned out to be something simple and mechanical like the power switch, it would be totally worth my time to tear it down and repair it.
这个答案有帮助吗?
得分 0
1条评论:
Thanks, JS. I'm feeling a little stumped, because Apple says they essentially replaced the entire guts of the iMac and it still was stone-cold dead. At some point you gotta ask, how could that be?
I'm glad your repair worked out!
完成的
添加一条评论
添加你的答案
JS24 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 9,571
