跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
One of the click wheel buttons not working
I'm trying to fix an iPod Classic with a broken click wheel button (play/pause). All of the other buttons are working. From previous questions I've seen people suggesting to replace the click wheel, but I'm afraid that won't solve the problem (since clicks are registered by the buttons underneath, black dots on this picture.
Is there anyone with the same problem that fixed this by replacing the click wheel itself? Or any other suggestions?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@lpirar one thing you can do is measure the switch itself. Attach the leads from your multimeter to the bottom two contacts, you should see that the switch does have some resistance, and total continuity when depressed. If the switch itself checks out okay, you may have to replace the clickwheel or at worst the logic board. Make sure that the clickwheel can make contact with the switch. Sometimes the little rubber bumpers on top of the microswitches come off and preventing proper contact.
Open
Depressed switch
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the information, I'll give this a try. Let's hope it's the clickwheel itself :)
完成的
添加一条评论
Hello, i just resently replaced my click wheel on my ipod video and its wont scroll or click on anything. when i swith the hold swith the backlight will come on and the only inputs that the ipod will recieve is a soft reset when i hold down start and select. But thats it and nothing else.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lucas Pirard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 763
