跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
I got an Already Used iPod
So I got an iPod that is disabled an now I have to reset it and I have no clue how, and I can't have the person go into their iTunes and reset it because they forgot and I really need this iPod to work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@lunarsonarr if it is iCloud locked there is no way for you to reset it unless you get the previous owner to do so.
这个答案有帮助吗?
得分 2
4条评论:
Umm... Activation lock wasn't a thing until iOS 7... There is no iCloud lock. He means that it is disabled.
完成的
@gigabit87898 you are correct but if the iPod is running ios 7 and does indeed have Activation Lock on it, then only the original owners password will unlock it. So you are making the assumption that it has iOS less than 7
完成的
This an an iPod touch it's not a iPad.
完成的
Sorry.Spelling mistake
完成的
添加一条评论
Get iTunes running on a computer. While holding the cable plugged into the computer, press the home button. Make sure it is off first. About a half second after you start holding the home button, plug in the charger. Keep holding the home button. One it shows a charger and a iTunes logo, let go of the home button. Click restore on iTunes. Hit next a bunch of times and it will be like new.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kay Lar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 389
