跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
My Wii won't read any discs.
My Wii won't read any discs. It will acknowledge which disc has been put in, but then it says that the disc can't be read. 30 discs can't suddenly be bad. What is up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
Hello Tina,
It sounds like your DVD Drive is not recognizing discs in the drive. Try using this guide to manually clean the lens, or replace as necessary. If you do not feel you are up to lens replacement you can try replacing the drive wholesale.
Be aware that if your Wii has been under heavy use (such as moving it frequently) your solution could be as easy as a loose cable from the motherboard to the DVD drive. Refer to this guide to make sure all your cables are solidly seated.
Hope this helps.
Nintendo Wii Motherboard图片
指南
Nintendo Wii Motherboard Replacement
难度:
中等
1 - 3 hours
Nintendo Wii DVD Drive Lens图片
指南
Nintendo Wii DVD Drive Lens Replacement
难度:
中等
1 - 2 hours
Nintendo Wii DVD光驱图片
指南
如何帮任天堂Wii主机更换光驱
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tina 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 25,364
