跳转到主内容
GoPro Hero5 Black是GoPro于2016年10月发布的高清防水运动相机。具有4k分辨率录制和语音控制,触摸屏显示和内置WiFi功能。
Why is my LCD Screen not working?
My LCD screen is not responding to touch anymore.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
Hello, I've also an issue with the LCD screen. The screen remain black when I switch on the gopro. Everything seems to work normally even the screen is responding to touch. I tried everything, I don't think it's the battery as the problem is the same when I plug the gopro.
完成的
I've have done alot of LCD Repair, Most time is Flex Cable gets worn out, i dont why.
完成的
I can't do anything it is not responding G to touch a d dark
完成的
yes. i don't know why.
i just open after charge.
after that , i try push button on, its on , but not working , lcd screnn also not working
完成的
I have the exact same problem- my GoPro will turn on, but the screen is still black.
完成的
显示更多的3条评论
添加一条评论
2个答案
最有帮助的答案
I fixed mine myself, You need to replace the whole LCD, the flex cable get damage in time because of how they bend it.
这个答案有帮助吗?
得分 1
1条评论:
Hey Desdry, where can I get a new LCD?
完成的
添加一条评论
If your GoPro Hero5 can turn on and only LCD touch screen is not responding it could mean that the LCD is faulty. Otherwise, there may be something wrong with the motherboard or the connection between the screen and the motherboard. To check for a severed connection, you will have to open up the Hero5 and take a look. You can refer to the troubleshooting guide for more information.
这个答案有帮助吗?
得分 0
1条评论:
what do I do if the LCD is faulty?
完成的
添加一条评论
添加你的答案
Bradley Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 14,703
