跳转到主内容
The Dell Inspiron 1440 is a laptop that was made in 2010. It comes with a webcam and Windows 7. Model Number: PP42L
7 个问题 查看全部
When power on the laptop, screen is black and Beeps two times
My laptop was working fine but recently when I tried on switch on, dislay does not work. All the lights starts and also DVD room gives the voice but nothing on LCD. After some time it beeps two times. Tried to connect with some other monitor still it does not work. So I concluded that it's not the problem with LCD.
Kindly suggest any thing that what's the problem and what can I do for the fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@mudasir this is can be caused by loose memory or bad video. Remove all memory modules and check if the beep code changes. You can also try to reset the BIOS by removing the CMOS battery, the main battery, remove the RAM and AC power adapter. Then hold the power button down for 15 seconds or longer. Reassemble and see what you get. Here is how to disassemble your computer. You can download the service manual from here.
这个答案有帮助吗?
得分 2
2条评论:
@oldturkey03 I tried by doing the same. removed the battery and adopter and hold the power button 60 sec. But it did not worked.
完成的
You checked your RAM module by removing those and seeing if the beep code changes?
完成的
添加一条评论
添加你的答案
Mudasir Rao 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 15
总计 354
