跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Will iPhone 7 keep it's water resistance after repair?
I cracked the camera lens on my iPhone 7. The crack is noticeable with direct sunlight. In order to replace the camera lens iPhone needs to be disassembled. I am wondering if the iPhone 7 will loose its water resistance after?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
添加一条评论
8个答案
已选择的解决方案
The question to ask your local technician would be...."Do you replace the adhesive strips on the display assembly when you are putting the phone back together?" If they do, the phone should keep its water resistance. If they don't, then No that iPhone 7 will no longer be water resistant. I feel this is going to be a huge issue when the iPhone 7 starts being repaired by third parties.
这个答案有帮助吗?
得分 13
5条评论:
adhesive strips can be changed, more important to ask for warranty against water intrusion on repair.
完成的
I highly doubt anyone is going to warranty water intrusion, would you? There's a reason Apple is not calling their waterproof iPhone 7 what it is, waterproof.
完成的
I don't think there is any phone company warranting water resistant phones under liquid damage. There's no reason for them to.
完成的
Thank you! This will help me tons when I speak to the tech repairing my phone!
完成的
This was extremely helpful as well! Thanks! @lpfaff1
完成的
添加一条评论
最有帮助的答案
iPhone 7 display sealing adhesive is already available on Chinese sites. If you clean the old adhesive off using alcohol and apply the new one correctly, the screen will still be waterproof.
Can't say about the camera because it is sealed differently. If you push the camera internal bezel off, you will have a hard time locating new parts since they came welded onto the casing. The lens is glued onto the bezel, you have to make sure the bezel and the lens are also sealed.
After repairing everything, there is a simple method to test waterproofness. Tape over the speaker/vent grills on the bottom, take out the sim tray and try to suck air through it using a hand vacuum pump, if the pressure does not leak back into it slowly, it is sealed properly. You will have to find a way to connect the hose to the sim slot and seal it for the test though.
https://item.taobao.com/item.htm?spm=a23...
这个答案有帮助吗?
得分 14
6条评论:
Great answer!
完成的
I did notice the adhesive but do not understand the Chinese lenguage to order the part. I am trying to buy an Iphone 7 replacement screen, adhesive + repair tools. Do you know howmutch this is totally going to cost me ... can you guide me so I can order everything I need ? Thanks in advance! Btw I live in the Netherlands.
完成的
The adhesive costs almost nothing. The problem is that to buy it from outside of China will cost you big time on shipping. Also if you plan to buy replacement screens, make sure the earpiece speaker/top microphone hole came with waterproof grills fully preinstalled. I'm sure most suppliers don't do that and I haven't located all the parts required and the correct way to assemble them to make sure the hole is still waterproof.
完成的
about that test doesn't seem very reliable as the waterproof sealing let the air go trough and not the water, otherwise speakers and microphone wouldn't work, also suck or pump air into the phone will means damage speakers as if put under pressure could ruin the membrane they are made of!!
完成的
Regarding the method of using air, the iphone 7 has a baffle to equalise pressure inside the phone. So is this test accurate?
完成的
显示更多的1条评论
添加一条评论
Mariuz, If repair is made by a good Technician to factory standards or better phone should be fine, although there is always a chance not. Take iphone in for diagnoses, estimate for repair and ask of warranty. Good luck.
这个答案有帮助吗?
得分 3
1条评论:
I agree with your ideas
完成的
添加一条评论
The iPhone 7 has special water resisting gaskets put into place. Removing them can lessen the water resistance. You should replace them as they originally were to the best of your ability.
这个答案有帮助吗?
得分 0
添加一条评论
Another option is to go the AppleCare route. The Verge posted an article a month ago, saying that Apple had dropped the price on iPhone 7 repairs by a significant amount relative to the 6/6S. It may make a factory repair cost-competitive compared to third-party or DIY. And at least an in-house repair makes Apple responsible for ensuring that the device is still waterproof afterwards.
Apple quietly made it cheaper to replace a cracked iPhone screen
这个答案有帮助吗?
得分 0
添加一条评论
does earpeice replacement damage its water resistant??
这个答案有帮助吗?
得分 0
添加一条评论
I just cracked my screen last night and my dad’s repairing it on Monday when my screen comes in. Will my iPhone 7+ still be water resistant after just putting on a new screen. I don’t take my phone near water I just wanna make sure if it will be water resistant or not so I can bring out my lifeproof case
这个答案有帮助吗?
得分 0
添加一条评论
My iphone 7 was a water damage and its not turning on. Is there anyway to make is to work normally please help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mariusz Pudzianowski 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 58
总计 103,389
