跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
Dead spot in new digitizer. Replaced twice. Dead spots.
Customer brought in an iPad Pro 12.9" with a cracked screen. I replace the screen and soldered the new one on properly 100%. Customer has issues with the dead spot on the screen. So I ordered a brand-new digitizer assembly and install that one. Exact same issue as the first one. Anybody have any suggestions? No apparent damage to the control board and soldering is good. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Same supplier? Seconds?
完成的
Different Supplier. LCD is good on both.
完成的
添加一条评论
2个答案
then the controller board is bad, simple
Update (11/11/2016)
sounds to me like proccess of elimination its the controller board, too much heat, etc can damage a controller board, hope you find a solution.
这个答案有帮助吗?
得分 0
添加一条评论
lcd is not ok failure
这个答案有帮助吗?
得分 -2
1条评论:
LCD is perfectly fine on both. Ordered from 2 separate manufacturers, dead spot in same exact area.
完成的
添加一条评论
添加你的答案
GadgetERService 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 480
