跳转到主内容
加入维修社区 - 创建账户
2014 年 6 月发布,可通过型号 B051 识别。
I have a serious Problem
Hello I would like to know if there is a way to fix this but my beats solo² s460 stop working when it was playing audio and the device I was using to play it disconnected and the beats froze as soon as it disconnected it was stuck on a blue light and I held down the power button for approximately 10 secs but It was frozen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I've fixed it the buttons were shifted when I turned them on so the power knob wasn't touching the button to turn it off
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi Adain, I would give them a hardreset, If this doesn't work it's an indication that the issue may be hardware related and will need a technician to check soldering, plugs etc.
Press and hold the power button for 10 seconds.
Release the button.
The battery Fuel Gauge LEDs will all blink white, then the first will blink red—this sequence will happen three times.
When the lights stop flashing, the reset is complete.
这个答案有帮助吗?
得分 1
2条评论:
Didn't work thanks though
由完成的
You could attempt to remove the battery and reset it that way.
由完成的
添加一条评论
添加你的答案
Adain Asir 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 672
