跳转到主内容
GM旗下的SUV和卡车生产商悍马汽车的修理和支持指南
28 个问题 查看全部
Heater core replacement on a 2003 hummer h2
Today we blew the left side heater hose. It was actually the plastic nipple comeing out of the firewall the hose ataches to. 1 can I just replace the nipple and how. Or 2 is it part of the heater core and how do I replace it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
@dragon883 this is an old question but somehow popped back up. Answering it just for completion sake since it may no longer be an issue by the OP but may help someone else looking for the same answers.
"HEATER CORE REPLACEMENT
Removal Procedure
1. Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement .
2. Remove the screws from the heater core cover.
3. Remove the heater core cover (1) from the HVAC module assembly (2).
4. Remove the heater core cowl gasket (1) from the heater core (2).
5. Remove the heater core (1) from the HVAC module assembly (2).
Tools Required
J 43181 Quick Connect Connector Removal Tool
Removal Procedure
1. Drain the engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2. Using the J 43181 disconnect the inlet heater hose from the heater core.
1. Install the J 43181 to the heater core pipe.
2. Close the tool around the heater core pipe.
3. Firmly pull the tool into the quick connect end of the heater hose.
4. Firmly grasp the heater hose. Pull the heater hose forward in order to disengage the inlet hose from
the heater core.
3. Using the J 43181 disconnect the surge tank outlet hose from the heater core.
4. Firmly grasp the heater hose. Pull the heater hose forward in order to disengage the surge tank
4. Remove the accumulator. Refer to Accumulator Replacement .
5. Remove the instrument panel carrier. Refer to Instrument Panel (I/P) Carrier Replacement in
Instrument Panel, Gauges and Console.
6. Remove the HVAC module drain hose.
7. Disconnect the electrical harnesses and the ground connections from the HVAC module assembly.
8. Remove the nuts (4) from the HVAC module assembly (2).
9. Remove the bolts (3) from the HVAC module assembly (2).
10. Remove the HVAC module assembly (2) from the vehicle (1).
这个答案有帮助吗?
得分 1
添加一条评论
It's part of heater core it can be fixed but won't last long, needs to be replaced with at least mid grade new heater core, if u buy cheap grade heater cores you'll be having problems again in under 2 yrs. Know from experience the decision is yours, hope this helps and Gd luck
这个答案有帮助吗?
得分 0
添加一条评论
In case someone else comes along and sees this the above answers are incorrect. The metal heater core coming out of the firewall has these plastic connectors that the hose attaches to. The plastic connector is easy to replace and costs about $6 and the quick disconnect tool is about $9 from any local auto parts store. You do NOT need to replace the heater core or tear apart the dash to replace the plastic connectors that the hose attaches to. Takes about 30 minutes if you take your time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 28
总计 4,060
