跳转到主内容
加入维修社区 - 创建账户
Game Boy Pocket 于 1996 年由 Nintendo 发行。它是 Game Boy 系列中的第二款设备。
Gameboy Pocket Inductor Replacement
I have an old Gameboy Pocket unit that was dropped and does not power on. After disassembly, the only damaged part appears to be a polymer encased inductor mounted on the small sub-board in the bottom corner of the PCB. The polymer canister that holds the inductor coil is breached and the wire has become partially unraveled. The canister is labeled as follows:
066
Yy
I've done some looking around online, and I haven't been able to find anything about this particular part or how to find a replacement. The only option I've been able to come up with is scavenging an entire sub-board from another unit. Any help is appreciated.
Update (10/06/2016)
Hope this helps.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Hi,
Could you please send a picture of the damage component ?
JM
这个答案有帮助吗?
得分 0
1条评论:
Let me know if you want any other images. If needed, I can de-solder the sub-board to see it in more detail.
由完成的 分享
添加一条评论
添加你的答案
Sakurazaki Sakai 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 21
总计 1,388
