跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for the first generation Grand Cherokee ZJ, an upscale mid-size SUV built by Chrysler's Jeep division.
Were is my camshaft sensor at.
Were is the camshaft sensors and how do I get to it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Unfortunately, this is NOT accurate for a 1998 Jeep Cherokee Sport (classic) powered by the 4.0 six cylinder engine.
完成的
添加一条评论
5个答案
最有帮助的答案
@crazymomma you did not tell us the engine size for your GC. Here is some imformation from a service manual. Should make it pretty straight forward. On the 4.0 the Camshaft Position Sensor (CMP) is bolted to the top of the oil pump drive shaft assembly. The sensor and drive shaft assembly is located on the right side of the engine near the oil filter.
REMOVAL - SENSOR ONLY
* Disconnect electrical connector at CMP sensor.
* Remove 2 sensor mounting bolts.
* Remove sensor from oil pump drive.
On the 4.7L engine the Camshaft Position Sensor (CMP)is bolted to the front/top of the right cylinder head.
REMOVAL
  • It is easier to remove/install sensor from under vehicle.
  • Raise and support vehicle.
  • Disconnect electrical connector at CMP sensor.
  • Remove sensor mounting bolt.
  • Carefully pry sensor from cylinder head in a rocking action with two small screwdrivers.
  • Check condition of sensor O-ring.
INSTALLATION
  • Clean out machined hole in cylinder head.
  • Apply a small amount of engine oil to sensor O-ring.
  • Install sensor into cylinder head with as light rocking action. Do not twist sensor into position as damage to O-ring may result. CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to cylinder head. If sensor is not flush, damage to sensor mounting tang may result.
  • Install mounting bolt and tighten to 12 Nm (106 in. lbs.) torque.
  • Connect electrical connector to sensor.
  • Lower vehicle.
这个答案有帮助吗?
得分 3
1条评论:
That set up is not for a 98. 95 through 98 they placed the camshaft sensor under the distributor cap.
完成的
添加一条评论
What if a socket gets dropped into the hole the sensor goes in
这个答案有帮助吗?
得分 0
添加一条评论
Buy a magnetic pick up tool and cross your fingers. If extraction of successful pat yourself on the back got a cold beer I revel in the accomplishment that you managed to pull off.
这个答案有帮助吗?
得分 0
添加一条评论
I lost my keys bought a new ignition had a friend tht was scraping theirs got the doors put them on mine. But now my girl set the alarm off and couldn't get it to go off so I've been trying a few things got alarm to go off but still isn't getting fuel after a few seconds it dies bc theanti theft wont pump gas after the first turn of key
98 jeep grand cherokee
这个答案有帮助吗?
得分 0
1条评论:
moser1daddy, I recommend to start your own post and not put your problem under a cam shaft position sensor post if you want more people to look at your anti theft problem.
完成的
添加一条评论
If it's a 93 or 94 it's inside your distributor, take off Distributor cap, mark its position, then pull the whole distributor out, the cam sensor is at the bottom
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeanie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 31
过去 30 天: 109
总计 17,823
