跳转到主内容
加入维修社区 - 创建账户
First generation, based on the Ford C1 global platform.
Tail light does not work
Hello,
My left tail light does not work. Bulb works fine. Break works fine. Horn works fine. I am not sure why just the tail light is not working.
Mazda 3 2008.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
I put the bulb on the right side and worked fine. But why the same bulb would work on the left side when I push the break but not the tail light, weird.
完成的
Sound slike you are having trouble with the bulb casing. Have you checked the contact on the light itself to see if it has power?
完成的
how do i get a new casing and what is the correct term?
完成的
It is part of the tail light wiring harness. You do want to check the connectors first. See if you have power on those.
完成的
添加一条评论
1个答案
已选择的解决方案
Qossay Takroori did you make sure that the bulb is the right bulb? The contacts are different on different bulbs. If the bulb is right, check the contacts with a mutlimeter and see if you have power on that. The contact inside the connector is positive, use some bare metal as ground. If you do not have power on the connector, check the harness to make sure it is not severed somewhere.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Qossay Takroori 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 5,561
