跳转到主内容
加入维修社区 - 创建账户
Sony VAIO 系列笔记本电脑(型号 VPCEC1M1E)的维修信息。
Screen Display wont show!.
I turned on my laptop but then the display wont show only the light power button on. I tried to turn it off but the light power button still on and cant turn off so I had to remove the power cable. [THE DISPLAY IS NOT CRACKED OR BROKEN. IT JUST WONT SHOW AND NOT WORKING]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
https://esupport.sony.com/US/p/model-fin...
Go to that site. Select your model, then put up the link to that webpage.
由完成的 分享
添加一条评论
2个答案
1. in order to test your laptop (graphic card) get a VGA-VGA cable and connect the laptop to your TV or a desktop monitor (hope that you have a TV that suports PC input) and start the laptop.
If there is no output on TV mabie you have a broken graphic card.
2. check the laptop's memory.
here you will have to poen your laptop and remove one dimm of memory (in case you have two) or if there is only one slot - with a module on, copy the details from it (memory module) and borrow a similare module to test if that is the problem.
Yours,
Oscar
这个答案有帮助吗?
得分 0
添加一条评论
pull the ram out and shake it then put it back and turn the laptop on but with a charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iszel mori 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 15
总计 1,153
