跳转到主内容
The Canon PIXMA MP620B is a color inkjet printer with wireless networking released in 2008.
Printer says it needs repair
Printer does not communicate with the Mac.
Says there is an Error.
The Printer Utility Software presents a dialog box that says:
"Error code B200 has occurred. Contact the service center."
Where can I take or send the printer for service?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
2018- I had the same problem after trying to print from another room using my iPad. I tried several times and I think I had my printer confused. I was already picking out a new printer when I tried what someone said to do…..with printer turned off I moved printer head to the center with my fingers, turned printer on, when I saw the ink cartilages move half way to the left I closed the cartilages cover and put the top down quickly. I had to do this 2 or 3 times. It now works perfect. Thanks for the help.
这个答案有帮助吗?
得分 3
添加一条评论
oscarsmom222 that will depend on where you are located. A Canon autorized service center should pop up by using your favorite online search engine.
I'd try so simple things first. Like this one from Canon:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Check on here for a few more ideas.
这个答案有帮助吗?
得分 0
1条评论:
I did all the above tricks to no avail, so, I guess it has to go to a repair shop or shop for a new printer.
完成的
添加一条评论
添加你的答案
oscarsmom222 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 7,081
