Tv turns on back light only
I took photos of the back of the TV circuit boards.
I have a LG 60pz950 Plasma 5 years old was working fine then one day turned on the tv and you see the tv is on but no picture and also if you select tv source etc nothing shows on the tv screen you would usually see the tv menu. I ended up buying a new TV. Do you think its worth getting this repaired? I spent 2k on this new tv. The LG was $1500. I have been checking these groups to see if I can repair it myself. Thanks
7条评论
I added photos of the circuit boards
由 Mike 完成的
I added the tv screen turned on showing the screen gray image when turned on.
由 Mike 完成的
I added the repair kit besides the fuse I do not see the other parts on the board to replace.
由 Mike 完成的
I will take the board off and take photos of both sides. Thanks
由 Mike 完成的
[image|933632][image|933631] Both sides of my Ysus board I need to diagnose it and use the repair kit.
由 Mike 完成的
显示更多的2条评论
