跳转到主内容
加入维修社区 - 创建账户
Works fine until a battery is connected, then shuts off
Hi All! I've got an A1138 PowerBook that works fine on AC power with no battery attached, but when I connect a known-good battery (I've tried several known-good batteries), the machine immediately shuts off. The AC adapter light, which glows bright green without the battery in, goes out completely and erratically flickers amber when you connect a battery. The machine won't power on with a battery in except occasionally, and quickly goes off again. Again, this all happens when a battery is connected, and without a battery, everything's fine. My first guess was the battery connector, but I replaced that with no change. Next up was the DC-in, and I tried 3 I had sitting around, although I think they all may be flaky to some degree, so I'm not confident I've properly ruled out the DC-in. I've got a good DC-in on the way, but I'm not sure that's the problem...this seems more like a short, or an electrical issue. Any ideas? I know it's not the RAM, AC adapter, resets, etc. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Got the replacement DC-in, and no luck. It behaves exactly like the other, which is perfectly, until you add a battery, and then the machine shuts off, and the AC light glows off and on amber.
完成的
添加一条评论
1个答案
已选择的解决方案
OK, this is a shot in the dark. Disconnect the battery connector cable from the logic board and insert a battery to see if it's physical.
这个答案有帮助吗?
得分 4
2条评论:
Without the battery connector nothing happened. Good idea though!
完成的
Sounds like a logic board to me. You guys have such interesting problems. + to both.
完成的
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 2,568
